lr-eddyfi
Run in VM issues
I'm trying to configure the vm feature so I can test the installer without having to run the process manually.
I have a W11 VM on hyper-v on a server (not my local machine). I was able to configure the connection without issue. Running the "Run in VM" tool seems to connect to the machine, however it reports that the Advanced Installer Tools are not running on the VM.
  • I've verified that they are installed and running on the VM
  • I've ensured the snapshot used is a standard snapshot, captured with the tools running and logged in
  • I've tried disabling the firewall on the VM
How do I troubleshoot from here? Thanks.
Re: Run in VM issues
Is the VM connected to the internet?
If so, it should be able to download and install the Advanced Installer tools.
We can try to manually copy, from the installation directory of Advanced Installer:
C:\Program Files (x86)\Caphyon\Advanced Installer 23.6\bin
the osprovision.exe and install it manually in our VM.
Could you please try that and let me know if it helps?
lr-eddyfi
Yes, I installed them manually, they appear to be running on the VM no problem, but advanced installer can't connect to them for some reason.
First of all, please accept my apologies for the quite delayed reply on this.
If you manually installed the tools and this still did not help, it most likely means the issue is with the connection to the VM.
Here are a few things that we can try:
1. make sure the VM is interactively logged in (a user is logged in)
2. if you are using Hyper-V, check the integration services and ensure all of them are enabled
3. test network connectivity to the VM. From the machine where Advanced Installer is running, verify that the guest VM is reachable.
From a PS window, we can use the ping to see if the VM is reachable and also Test-Connection to check the port.
ping <VM-IP>
Test-NetConnection <VM-IP> -Port 9987
4. ideally, the host and the VM should be in the same subnet, or at least reachable by ping. Please also check this.
5. could you please also check if the "File and Printer Sharing" is enabled on the host machine?
