Mike Watts
Installer Log File
I have a report of a problem when installing at a remote site ( although I tried it without error on 12 combinations here! ). Is there a log file which will give me a bit more information on what has gone awry?
Mike Watts
Mike
Hi Mike,
You can use "Run and Log" option from the "Project" menu of Advanced Installer.
If you want to test the MSI you can also use the /l command line option of MsiExec.exe.
For more details on this command line option please visit:
http://msdn.microsoft.com/library/defau ... ptions.asp
Mihai Bobaru
Advanced Installer Team
Mike Watts
Installer Log
Hi Mihai,
Thanks for your ( rapid! ) reply - that looks like a generally useful set of command line options to know anyway.
Cheers,
Mike
