Mitch
Vista UAC and Regserver
Vista won't allow me to register my application using a custom action if the UAC is enabled, even if the user has admin priviledges. I assume there must be a way to do this using the COM section of AdvancedInstaller Pro but I can't seem to get it to work. Can you provide an example or step by step instructions?
Mitch
gabriel
Contact: Yahoo Messenger
Please try using a custom action without an impersonation property in Execution Options group.
Let me know if using no impersonation resolves your problem.
Ovidiu
_________________
Ovidiu Blejdea
Advanced Installer Team
Mitch
Thanks, that worked. However this user has Admin Priveledges and I though I haven't tested yet I presume it should work with a Standard User who requires elevation to install the program.
Mitch
gabriel
Yes, it should work fine.
Glad to be of service,
Ovidiu
________________
Ovidiu Blejdea
Advanced Installer team
Mitch
Oops, not done yet. Since self registration for a COM DLL didn't work on Vista with UAC Enabled I tried the same strategy of using a custom action to register:
RegSvr32.exe /s "[#dll]"
Deferred with no impersonation
and ended up with an Ole Error. Any ideas on how to make this work?
Mitch
Cosmin
Have you tried registering the COM with the "Extract registration info from native library" option? Also, how did you configure the custom action which runs regsvr32.exe? Are you using a configuration similar to the one in this thread?
http://www.advancedinstaller.com/forums ... php?t=4574
Cosmin
Mitch
Yes, I tried the Auto Register/Self Register option first and got an Ole Error and then tried the strategy that worked with registering the COM server.
Property Name: RESULT_PROPERTY_REGSVR32.EXE
Source Type: Executable
Command Line: /s "[#RockWare_GIS_Link_2.dll]"
Synchronous execution, check return code
Always Execute
Expression: NOT Installed
This appears to be a common Vista MSI problem and the only solutions I could find were to turn off UAC.
Mitch
