danc81
VerifyRemoveDlg from Add/Remove programs
I have a custom option on the VerifyRemoveDlg dialog which allows an installed program to run before the uninstallation. When I select uninstall, either from the Add/Remove programs or the shortcut in the start menu I do not see the dialog.
How can I present the dialog on uninstall?
Where is the latest event I can call the custom action from before the application is removed?
Thanks.
Cosmin
Please note that Windows Installer performs a silent uninstallation when using the "Remove" button in "Add or Remove Programs", therefore you cannot show a Windows Installer dialog (in your case "VerifyRemoveDlg").
A simple solution is to go to the "Product Details" page and check the "Disable Remove" option. This way, the user will be able to select only the "Change" button and the MSI will enter into Maintenance mode (full UI).
Since the Maintenance mode shows all the uninstall dialogs, it will also show the "VerifyReadyDlg" dialog.
Cosmin
danc81
That worked perfectly.
Just one question. I have a checkbox on the final screen of the first time install but I do not want to show it at the end of the maintenance section but it appears on both. How can I hide it for maintenance?
Cosmin
In order to do this you can use Control Conditions in the "Dialogs" page. Here are the steps:
- select the checkbox in the "Dialogs" page
- select the "Control Conditions" tab in the "Control" section
- create these conditions:
NOT Installed                Show
Installed                    Hide
You can read more about Control Conditions here:
http://www.advancedinstaller.com/user-g ... conditions
Cosmin
danc81
Perfect! Thanks.
lesliehedzg
Re:
Perfect , but i dont understand
Where do I add uninstall dialogs? Where do I specify that two of my dialogs are uninstall?
best regards,
Leslie
Re: VerifyRemoveDlg from Add/Remove programs
Hello Leslie,
Please read my reply from the "Combobox: Text vs. values" thread.
