BillStewart
Standard choices in permissions list
I'd like to express my support for the Permissions tab feature request mentioned in the following post:
http://www.advancedinstaller.com/forums ... php?t=6676
It would be greatly helpful if there was a way to select standard permissions rather than having to check the boxes individually.
Thanks!
Bill
Cosmin
Re: Standard choices in permissions list
This feature is scheduled for the 6.4 version of Advanced Installer.
Please note that the standard permissions are set by default (when no checkbox is selected). Therefore, a file with no permissions set for it will use the permissions of the user which works with the file.
Cosmin
Return to “Feature Requests”
