BillStewart
Scheduled task based on a condition
It would be useful in some scenarios to have a condition for scheduled task creation. I know that if the executable isn't installed the scheduled task is not created. However, it would be useful in the case where the executable is always installed but you don't always want the scheduled task to be created (for example, a dialog check box could enable or disable it).
Thanks!
Bill
Cosmin
Re: Scheduled task based on a condition
Hi Bill,
This feature has been implemented in the 6.3 version of Advanced Installer which is scheduled for release in the near future.
Cosmin
Return to “Feature Requests”
