sashasch
ComboBox handling
Hi to all!
How can I handle the ComboBox choice?
I have text field (Edit Box) and need to change it's properties, according to the ComboBox choice.
I can enable & disable the text field, by using Control conditions, but how to create it's text content, if it is not exacly
the choosen value, but based on one.
P.S. I have finded he funny bug with lable (Static Text): where I set it's Text according to any variable and then change
the variable, the new value prints over the old one (previous value is not cleared).
Cosmin
Re: ComboBox handling
Can you please give me more details about this? How exactly is the edit box affected by the combo box? Will they show the same value?
Note that we have a how-to which explains a similar situation.
This is a known Windows Installer bug and it happens because the text uses transparency. The solution is to set the "Transparent" attribute to "False" in the Properties pane.
Cosmin
