danc81
Asking for installer on uninstall
We seem to be experiencing an issue on some machines (not all) where when we select "Remove" from the "change" options in add/remove programs the installer prompts us to locate our installer executable file. This is becoming a problem as most people do not keep the installer, especially when they select "Run" on download. What causes this? Is there a way to stop it?
Thanks.
Cosmin
Re: Asking for installer on uninstall
I'm not sure why you are encountering this behavior. Can you please send us the AIP which shows this problem to support at advancedinstaller dot com so we can investigate it?
Cosmin
Klemens
the same problem as I have: dialog box with English text "Select the installation package for [ProductName]".
First problem is why this not nice question is visible, second problem why in English when my setup is German language selected...
Dialog asks me about "exe" file in "System32" folder.
Have you any idea...
Thanks and regards
Klemens
Cosmin
Please note that the language selection dialog is shown by the EXE bootstrapper. When a package is in Maintenance mode (the Modify, Repair and Remove options) the cached MSI is used. Therefore, the EXE bootstrapper cannot be used to show the language selection dialog. Also, Windows Installer remembers the language of the installation and it will use the same language in Maintenance mode.
I'm not sure I understand the exact behavior you are encountering. Can you please send us a screen-shot with this behavior to support at advancedinstaller dot com? Also, can you please send us the AIP (Advanced Installer Project file) so we can investigate it?
Cosmin
Klemens
thanks for reply, here is screen of my problem...
Please notice there are no any bootstrapper in my setup (media configuration) we use only msi file.
Setup language was selected during project phase.
Regards
Klemens
Klemens
I am again...
It is in Maintenance mode when Remove action processing.
Klemens
Cosmin
There are two possible causes for this behavior:
- the cached MSI cannot be found
- the MSI needs to access a resource which cannot be found
Please test the package on other machines. If the problem persists, please send us the AIP you are using to support at advancedinstaller dot com so we can investigate it.
Cosmin
Klemens
please explain what is it "cached MSI" and where I can see it after installation?
Klemens
PS
I have sent file AIP to support
K.
Cosmin
Every time Windows Installer runs an installation, the MSI file is cached by Windows. This cached MSI is stored in the "C:\Windows\Installer" folder under a codified name.
Cosmin
