dannomite
Internet Explor Add-on
Are there any features in Advanced Installer to help create an installer for an IE6/7 activex add-on?
Cosmin
Re: Internet Explor Add-on
Please note that there are no special features required in order to package an Internet Explorer add-on (you can package it like you would package any other application). However, a feature which might help you is the Import Visual Studio Setup Project feature. With this feature you can import the VS Setup project of the add-on you create into an Advanced Installer project. After the import, you can customize the project the way you need.
If this doesn't answer to your question, please give me more details about the features you need in order to package an IE add-on.
Cosmin
