Bottesford
Feature Transfer Error
I'm getting the following error when trying to fire off the Google Sketchup (free) installer.
I'm using a custom action to launch the exe using the following options:
Source Type: EXE
Command Line: <nothing>
Execution Properties: Sync. execution, check return code
Execution Options: Deferred
Scheduling: Always Execute.
The same installer works fine on the same machine when not being called by my installer.
Any ideas on what's going on?
Cosmin
Re: Feature Transfer Error
If your installation package requires other packages to be installed, the recommended approach is to use prerequisites. You can add the Google Sketchup installation package as a prerequisite to your package in order to install it before your package is launched. Note that we have a prerequisites tutorial which may help you.
If this is approach does not suit your needs, please send us the AIP which shows the problem you encountered to support at advancedinstaller dot com so we can investigate it.
Cosmin
