aldebaran
Folder on the original .EXE
I have a project with Bootstrapper, so everything is in a big exe file (SETUP.EXE).
I developed a Custom Action that will copy some other files from the installation media to the APPDIR.
Now I want to find out in my Custom Action where the original SETUP.EXE is located. The properties [SourceDir] and [OriginalDatabase] seem to point the the location where the MSI was unpacked. How can I get the name of the folder where the SETUP.EXE sits?
Greetings
Stefan Hackenthal
http://www.aldebaran.de
canhuth
Re: Folder on the original .EXE
Hallo Stefan,
maybe this helps:
http://www.advancedinstaller.com/forums ... f=2&t=7738
With best regards
Clemens Anhuth
aldebaran
Thanks Clemens, this was helpful.
Regards
Stefan Hackenthal
