sgh915
file associations(open with) problem.
hi,
i tried to write arabic letters in description in file association and finish to build it, my build is fine.
but while i open with my file, programs name is not properly language name.
what is the problem?
regards
so
Cosmin
Re: file associations(open with) problem.
Please note that the description of the ProgID used for the file association is shown in a tooltip when the mouse cursor is above a file that is associated with your program. I'm not sure to what text you are referring, but I'm not sure if it can be translated.
Cosmin
