stradinov
updater silentall nofreqcheck problem
Hi, I attached two screen shots.
AI.jpg is the result of executing:
updater /silentall -nofreqcheck
AI2.jpg works OK and is the result of executing:
updater /checknow
In the same scenario, it seems to be a bug with the silentall option. I'm using v.6.4.1
Regards.
working
working
bug
bug
Cosmin
Re: updater silentall nofreqcheck problem
I'm not sure why you are encountering this behavior. Can you please send us the INI used by the Updater (it's in the installation folder) to support at advancedinstaller dot com or post it on the forum so we can investigate it?
Cosmin
stradinov
Sure, updates.ini and updates.txt files attached below.
Regards
updates.rar
(738 Bytes) Downloaded 301 times
Cosmin
We investigated this behavior and it is caused by a bug in Advanced Installer. This bug will be fixed in the next version (it is scheduled for release in the near future). Thank you for bringing this to our attention.
Cosmin
