divo
Dll Call
tried to kill process via Dll call C:\WINDOWS\system32\kernel32.dll Function name TerminateProcess
in my example an process named myfile.exe that must killed while uninstalling the package, but how to activate this and what can be filled in Action Data entry and Action text tab?
Cosmin
Re: Dll Call
Please note that a DLL custom action needs to be written in a certain way in order to be used by Windows Installer. Since the "TerminateProcess" function was not designed to be used by Windows Installer, you cannot use it in your package.
Please note that the User Guide contains the Detect and stop a process how-to which explains how to detect and stop a Windows process.
Cosmin
divo
Re: Dll Call
Hi ,
And what about 3rd party dll's and when can we use it inside AI in option call dll?
because we need always to call dll function in our software for example joining a pc to domain or retrieve some permissions of a user via call dll function as used in other scripting software like wise or installshield.
Cosmin
Re: Dll Call
Since Windows Installer supports only custom action DLLs and not just any DLL, I'm afraid that you cannot use any DLL as a custom action in your package (it must be written for a custom action). You can read more about custom action DLLs here:
http://www.codeproject.com/KB/install/m ... ction.aspx
http://bonemanblog.blogspot.com/2005/11 ... rt-ii.html
Cosmin
