And a couple of lines that have "ComponentRegister" in the them, but there appears to be one of those lines for each of the files that are being installed. Any help is appreciated. I can send the entire execution log if needed. Thanks.MSI (s) (B0:64) [15:24:50:467]: Doing action: RegisterTypeLibraries
Action 15:24:50: RegisterTypeLibraries. Registering type libraries
Action start 15:24:50: RegisterTypeLibraries.
Action ended 15:24:50: RegisterTypeLibraries. Return value 1.
MSI (s) (B0:64) [15:24:50:608]: Doing action: SelfRegModules
Action 15:24:50: SelfRegModules. Registering modules
Action start 15:24:50: SelfRegModules.
SelfRegModules: File: Registering modules, Folder:
Action ended 15:24:50: SelfRegModules. Return value 1.
MSI (s) (B0:64) [15:24:50:749]: Doing action: RegisterComPlus
Action 15:24:50: RegisterComPlus. Registering COM+ Applications and Components
Action start 15:24:50: RegisterComPlus.
MSI (s) (B0:64) [15:24:50:842]: Note: 1: 2205 2: 3: Complus
MSI (s) (B0:64) [15:24:50:874]: Note: 1: 2228 2: 3: Complus 4: SELECT `ComponentId`, `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed` FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Action` = 1 OR `Action` = 2)
Action ended 15:24:50: RegisterComPlus. Return value 0.
