carmbrad
MergeMod COM error
I have an enterprise installation project, I'm having this error when I try to build. I don't want to use MergeMod, how do I fix this? There is nothing listed under Project Details --> Merge Modules.
error.
Exception - Reason: You do not have MergeMod COM server installed on your computer. Please read in Help how to install it.
Cosmin
Re: MergeMod COM error
Please note that Advanced Installer is using the Merge Modules support provided by the MergeMod COM server. Therefore, you need to install the MergeMod COM server on your build machine.
Cosmin
