AidanGuy
Build Fails?
I'm trying to create a package of some software which we have 10 variants of. All other variants, and previous versions of this variant have worked but when creating the package i get the attahced error messages. Any Ideas?
screenshots of error message
msi error.JPG (97.34 KiB) Viewed 3193 times
Cosmin
Re: Build Fails?
I noticed you are using Advanced Installer 6.4. Please install Advanced Installer 6.4.1 or eventually 6.5.2 and try to build your project. If the problem persists even with the latest version of Advanced Installer please send us the AIP you are using to support at advancedinstaller dot com so we can investigate it.
Cosmin
AidanGuy
Re: Build Fails?
Project has now built successfully
thanks
