XXL66
.MSI doens not work in VISTA BUSINESS edition ?
I have a .MSI that works fine in VISTA HOME but doesn't seem to work in BUSINESS edition ?
What am i'm missing here ?
regards
Cosmin
Re: .MSI doens not work in VISTA BUSINESS edition ?
Please note that the packages created with Advanced Installer should work on all Vista versions. Can you please give me more details about the problem you are encountering? What is the exact behavior?
Cosmin
XXL66
WINDOWS INSTALLERS just says:
Cannot open this package, please contact manufacturar to check if this is a valid windows installer package (translated from dutch)
See attached screencapt
User is administrator and UAC is off.
What is wrong ? This package has been installed several times without any problems on other VISTA computers ...
regards
error opening MSI in VISTA
Cosmin
Most likely the problem is caused by the machine which shows this behavior. Please try upgrading or downgrading Windows Installer.
Cosmin
