cpdohert
How to specify an arbitrary user-specific file?
I have successfully verified the instructions here:
http://www.advancedinstaller.com/user-g ... -file.html
I am trying to generalize this method so that I can specify an arbitrary file outside of the MSI at install time. I am doing this by setting a public property named CONFIGFILE and passing it to msiexec: msiexec /i setup.msi /qn CONFIGFILE="spark.cfg"
Per the instructions at http://www.advancedinstaller.com/user-g ... -file.html, I am using a property-based folder and File Copy/Move operation. I am using these values for the File Copy/Move:
The arbitrary config file is not moved from the SOURCEDIR, although it is correctly expanded and used for the registry entries and the post-install launch.
What is the correct syntax for this? Is this even possible to do in this manner?
Cosmin
Re: How to specify an arbitrary user-specific file?
I'm afraid that the name of the source file cannot be formatted (it cannot use properties). This name is written as a text inside the MSI, therefore it can be set only to a hard-coded value (which may use wildcards).
Cosmin
