ACarpenter@msn.com
XML File won't update
I have an XML file installed to a subdirectory where I want to add the install path as an attribute.
I have created the xml file (Files Screeen - NEW XML), renamed it to match the source file (in the same directory and added [APPDIR]PDF to the appropriate attribute.
But when I run the install no entry is made.
I've checked the log file and doesn't show anything, so how can I figure out why this is not working?
Thanks.
Carp
ACarpenter@msn.com
Re: XML File won't update
Found the problem - the default setting on Elements is to ADD them,not UPDATE them so it was creating NEW nodes instead of modifying the existing ones.
