mng000
Use language selection to set reg key:
I am using the language selection dialogue box - is there a way i can set a registry key depending on what language the user selects (so that the default language my software uses can be the same as the language they selected)?
Mark
Cristi
Re: Use language selection to set reg key:
Yes you can. In the Registry page you create a new value and set its Data to
[ProductLanguage]
Cristi
______________________________
Cristi Costache
Advanced Installer Team
