J. Behrens
Problem with the maintenance plan
Hello Advanced Installer Team,
we bought Advanced Installer on May 30, 2007. This info comes from customer information page after input of the licence key.
Also there is a information about our maintenance plan on this customer page: "Your current maintenance plan is valid until November 30, 2008."
So the DropDown on the customer information site shows all versions from 3.0.1 up to 6.6.
Are they all valid for our maintenance plan?
We downloaded now the version 6.6. After installing this new version a dialog appears with info that our maintenance plan
has expired!
Whats wrong?
Thank you.
J.B.
Cosmin
Re: Problem with the maintenance plan
Yes, all the versions shown in the combo box are covered by your maintenance plan.
has expired!
Can you please specify the actual text in the message? Please note that Advanced Installer shows a notification if your maintenance plan will expire soon. This notification does not affect in any way your installed Advanced Installer copy.
Cosmin
J. Behrens
Hi cosmo,
thank you for quick reply.
The exact message you see on pic in attachment.
Regards
J.B.
Message Dialog
Message Dialog
Cosmin
I'm not sure why you are encountering this behavior. Can you please contact us at support at advancedinstaller dot com so we can verify your license information (perhaps there is something wrong)? In your email please specify the license key you used to register Advanced Installer.
Cosmin
J. Behrens
the problem is solved.
It was the wrong user we used for login.
Thanks.
