dvelitchkov
Advanced Installer 6.6 Crash on opening up AIP file
Hi Guys,
Everything was working fine until recently when I had to reinstall Advanced Installer on a fresh Windows XP SP3 image (I was using SP2 prior)
Now, whenever I open up one of my AIP files, Advanced Installer crashes with a generic Windows crash report. It says it's crashing in msvcrt90.dll, which is the VS 2008 SP1 C/C++ runtime, which I didn't even have installed. Installing it did NOT fix the issue.
Do you have any idea what might be the issue? I'm completely lost :(
I'm attaching a screenshot of the problem
Thanks!
P.S. I LOVE the product!
crash screenshot
crash screenshot
Cosmin
Re: Advanced Installer 6.6 Crash on opening up AIP file
I'm not sure why you are encountering this behavior. Does this happen with new projects or only with the ones you try to open?
If this happen with all projects (including new ones), please try reinstalling Advanced Installer. If the problem occurs only for old projects, please send us some of the AIP files which show this behavior to support at advancedinstaller dot com so we can investigate them.
Cosmin
dvelitchkov
:D
I figured out the issue. My projects used a path variable file on a network drive (which wasn't mapped properly) as well as synchronized folders.
Once I remembered to set the path variable location correctly and map the drive, it worked :)
Lo and behold, you guys just released 6.7 which fixes that issue anyway :)
It works now, thanks!
