mikefry
Failed(?) Installation
At the end of an installation, I am receiving this box.
This is displayed at the end of the installation. It says it failed but I'm not so sure!
The trouble is, I think this box is associated with some error 2826 messages that I am seeing in the log file
WinREG.zip
Contains an installation log file. I can't see any problems apart from the error code 2826 messages.
(20.88 KiB) Downloaded 255 times
I think these errors are unavoidable in a Pro installation, but correctable in an Enterprise installation. Aren't they to do with a lack of pixels to accommodate translated fields? Basically, the space you have allowed in the dialogue boxes is insufficient in some cases.
Cosmin
Re: Failed(?) Installation
The 2826 errors in the log do not affect the installation and they should be ignored. They are shown because the sunken line in the lower section of the installation dialogs exceeds the dialog boundaries.
The "Some of the updates failed to install property" error is usually shown if the update uses an incorrect detection criteria in the Updates Configuration project.
Any update defined in the Updates Configuration file uses a detection criteria. This criteria is usually a file or a registry entry which contains the package version. If it's not met after the update is installed, the Updater will show this message. Therefore, you need to make sure that you specified a correct file or registry entry in the Installed Detection section of the Update Properties page.
Cosmin
mikefry
Am I mis-reading the Installation Detection criteria?
I thought this referred to the version that was already installed, to make sure you were installing over an appropriate version. Now I look more closely, it appears to imply that this is for the version you are installing.
mikefry
cosmin wrote: The 2826 errors in the log do not affect the installation and they should be ignored. They are shown because the sunken line in the lower section of the installation dialogs exceeds the dialog boundaries.
I am dealing with some very unsophisticated users of a genealogy group. These people are, for the most part, elderly and would be extremely worried to see this kind of ignorable problem. Isn't there any way of avoiding it? Using another font?
Cosmin
Please note that the detection criteria is referring to the Update package, not to the original installation.
Please note that this error appears only in the installation log. Therefore, it is very unlikely that your users will see it. However, if you want to make sure that the errors disappear, you can try this:
- make sure you are using an Enterprise project
- in the Dialogs page select the "PrepareDlg" dialog
- in the Properties pane use the combo at the top to select the "BottomLine" control
- in the same pane set the "Width" field to 369
- do the same for all dialogs which use a bottom line
Cosmin
