dheerajjuneja
Unable to use aip file from version 6.6 with 6.7 or 6.7.1
We had created a product installer with version 6.6, but after upgrading installer, we are unable to open the AIP file anymore.
We get an error:
Error
Exception - File not found: I:\ProgramData\Caphyon\Advanced Installer\Repository\Dialogs\SQLConnectionDlg_0\SQLConnectionDlg_0.aip.
OK
Any ideas?
Dheeraj Juneja
Ionut
Re: Unable to use aip file from version 6.6 with 6.7 or 6.7.1
You are receiving this error message because your project uses a dialog which has been exported to the Repository and somehow the path to the Repository dialog seems to have been saved relative to the project.
Please send the AIP file to support at advancedinstaller dot com in order to investigate this issue.
Additionally, check to ensure that the following file exists (on C: not I:):
C:\ProgramData\Caphyon\Advanced Installer\Repository\Dialogs\SQLConnectionDlg_0\SQLConnectionDlg_0.aip
Ionut
Denis Toma
Advanced Installer Team
