danc81
Force new product code
Is it possible to force the generation of a new product code when the revision number changes? For example, if my version 1.1.1.1 becomes 1.1.1.2, I need to be able to upgrade the 1.1.1.1 in place which I believe requires a new product code but this only seems to be generated when I change the version to 1.1.2.1.
Is there a way round this? (I set the version on the command line)
Thanks.
Cosmin
Re: Force new product code
Unfortunately Windows Installer ignores the fourth field of the version. Therefore, for Windows Installer the version "1.1.1.1" is the same as "1.1.1.2". If you set a different Product Code for "1.1.1.2", Windows Installer will install it side by side with "1.1.1.1" (it will not upgrade the old version).
Cosmin
danc81
OK, thanks. I'll work around it then.
