From previous postings I cannot send the AI project since I have more than three projects erroring out.
You can send us all of them. However, if this is not possible, it is not difficult to repair them yourself:
1. Note the file, folder or shortcut name that causes the error when opening the AIP project in Advanced Installer.
2. Open the AIP file in a text editor.
3. Perform a case insensitive search after the name that caused the error (for example "defile~1.txt"). There will be at least 2 occurrences.
4. Replace the second and subsequent occurrences with something like "defil~19.txt" or something similar.
5. Save the AIP file and try opening it again in Advanced Installer.
6. If another error is received, repeat the steps 1->5 described above.
Regarding your second post, if you get the error "Exception - Current context does not contain an instance of this component [id ReadOnly]" then your AIP file might be corrupted.
Denis
