amejia
ERROR WHILE EXTRACTING FILES - LOOP
Hi when i try to install my application it seems that the installer fall into an infinite loop.
Does anybody have an idea on why is this happening?
amejia
Re: ERROR WHILE EXTRACTING FILES - LOOP
It get stuck when it is in the extrating file process
amejia
I have uploaded a screenshot
Cosmin
I'm not sure why you are encountering this behavior. Did you try leaving the installation run for a longer time to see if it extracts the files? Also, can you please send us the AIP (project) file with the problem to support at advancedinstaller dot com so we can investigate it?
Cosmin
amejia
Hi Cosmin,
I will send the project now. I leave the installation running for a long time (1 hour) and still in that infinite loop.
I found some reports about the same problem here but seems that there is no solution in them.
Hope to hear from you soon.
Alejandro Mejia
Cosmin
Hi Alejandro,
We investigated the project you provided and we found that the problem is caused by the extraction path you are using. Basically, the length of the extraction path cumulated with the length of some folder names and filenames exceeds the maximum length for a path (260 characters).
Since this is a Windows limitation, a solution is to use a shorter extraction path in the "Bootstrapper" tab of the "Media" page. For example, you can try using:
[WindowsVolume]
Cosmin
