awatt
DLL 'Extract Registration Info' Error
I was very pleased to see the new "Extract Registration Info" option in version 3.5. However, I'm wary of actually using it because of an error I keep getting.
When I set this option on a DLL, I get the following error message:
Exception - Invalid MSI identifier string [{CqA].
It seems to only happen the first time I set this option. If I turn it off and back on, or set it on a different DLL, the error does not appear. Restarting the Advanced Installer program brings it back.
The registry entries seem to be generated fine regardless of the error.
Ionut
Thank you for signaling this issue to us.
The problem has been solved and the fix will be available in the next version of Advanced Installer.
Denis
Denis Toma
Advanced Installer Team
