vilajzzz
Contact: ICQ
Incomplete JRE bundling
<mayBeImportant>
at first I've updated from version 3.3 to 3.4 - the patches generation between MSIs from 3.3 and 3.4 didn't work, so I downgraded back to 3.3.
<mayBeImportant>
The PROBLEM is that when I generate msi with JRE bundle, only the files from the JRE root directory are bundled.
Any idea?
Thanks a lot
Ionut
Although there were some major changes between versions 3.3 and 3.4, the patch generation between different versions should not fail. In order to determine why this occurs, please send us the build log to support at advancedinstaller dot com.
Regarding the second problem, it might have been fixed in newer versions of Advanced Installer. Please consider updating to the new 3.5 version.
Denis
Denis Toma
Advanced Installer Team
