hajuja
Customize copyright string for setup property
is there any possibility to customize our copyright string
from: "Copyright (C) Marvell" into: "©Copyright 2008-2009 Marvell®. All rights reserved.. "
I know this possibility from other installers like NSIS or InstallShield,
but I found in AI no property which contain the copyright string.
Hans-Juergen
Screenshot of setup properties.
Cosmin
Re: Customize copyright string for setup property
Unfortunately this string cannot be customized (it uses the company name you provided in your project). However, we will consider adding this improvement in a future version of Advanced Installer. Thank you for your suggestion.
Cosmin
hajuja
Thank you Cosmin for your quick reply!
