humanangle
can not open old project
Hi
I created a project one month ago and saved it in my desktop then copyed it to a cd
then I formatted my computer and install advanced installer
but I got a very strange message when ever I want to open that project I shall enclosed here with
the message . please help me fix this error
Cosmin
Re: can not open old project
You are encountering this behavior because the project is using a repository dialog which cannot be found on your machine. To fix it you can try this approach:
- create a new Advanced Installer Enterprise project
- in the "Dialogs" page add the "ReadmeDlg" dialog
- right-click the dialog and use the "Move to Repository" option
- open the project with the problem
Cosmin
humanangle
I created a new project as instructed and created ReadmeDlg
but advanced installer generate a name to the ReadmeDlg and change it to ReadmeDlg_0
and the project with the problem still showing the same message file not found..... ReadmeDlg
when ever I try to open it
Ionut
Please send the AIP file showing this problem to support at advancedinstaller dot com and we shall fix it for you.
Ionut
Denis Toma
Advanced Installer Team
humanangle
Thank you Cosmin
Thank you Ionut
I don't know how to thank you , at last I manged to fix that problem by creating new project and new dialogue ............. I appreciate your help
Thank you :mrgreen: :D
