hajuja
Change of the dialog mask UpgradeDlg
I`ve created 2 AI-projects "OldProject" and "NewProject".
NewProject was created by AI version 6.9
and OldProject was created by a previous version.
Later OldProject was updated to 6.9.
Both projects have the setting "Automatically upgrade older product versions."
Now I see that the UpgradeDlg dialog in both projects looks rather different. (see jpg file)
Why was the the dialog mask changed?
Is there any possibility in AI to change the appearance of the dialog in NewProject into the appearance of OldProject?
Hans-Juergen Jage
cyb
Re: Change of the dialog mask UpgradeDlg
Please note that the dialog in Advanced Installer hasn't changed. The dialog in the left is different than the one in the right because it seems that it is custom made by you.
Regarding your second question, yes, there is the possibility to change the appearance manually by editing the dialogs. That can be done in the Dialogs Page, unde the "User Interface" Tree. You can find more help about editing dialogs here .
cyb
Cosmin Budrica
Advanced Installer Team
