mfairbrother
How is Size calculated?
I have several files that get installed, executed, and then removed. Can the size of these items not get included in the reported size of the package?
Ionut
If those files are Custom Actions (Scripts, Executables, DLLs) attached to your package, their sizes will not be reported during the installation. However, the sizes of Installed Custom Actions will be reported.
Therefore, you should use Attached instead of Installed Custom Actions, if possible.
Denis
Denis Toma
Advanced Installer Team
