Beaniiman
Generation of License Activation Codes
Is there anyway for me to write an application to generate License Activation Codes on the fly. I figure since I know my Library Key, it would be possible. I would like to create a registration tool for our support team that could generate a registration code as needed as apposed to generating them ahead of time.
Ben
Cosmin
Re: Generation of License Activation Codes
Hi Ben,
If you are referring to the license keys used by the license module, I'm afraid they can be generated only by Advanced Installer. However, a future version will include a tool which will allow you to generate new keys. Using custom license keys is not supported because of the way the licensing feature works.
Cosmin
Beaniiman
I am very much looking forward to the tool. In my case, I do not need to create custom license keys. I would simply like to create the keys the same way advanced installer does. If you could provide the code or a component that I can reference so that I can generate keys from my application as apposed to opening advanced installer, that would work perfectly.
As it is now, I am either stuck with generating a bunch of keys and saving them (not my ideal solution) or reverse engineering your generation\validation routines (a huge waste of my time). If you have any other solutions for me, please keep me posted. My project goes to User Acceptance Testing in November.
Beaniiman
Any update on this?
Cosmin
I'm afraid we currently cannot offer an ETA for this feature. However, it has a high priority on our list and hopefully it will be available soon.
Cosmin
Return to “Feature Requests”
