Once we create a msi package it successfully installs. What exactly i want is when you install the older version or newer version of our application which is already installed, it should uninstall the previous msi and then it should it install the new one. Better if I know the uninstall file and where it will be present. How can it be solved.
Thanks in advance,
Harish.Y
