jordanh
Support for generating MSI installers from linux
The company I work for is seriously considering selecting Advanced Installer for creating MSI installers for windows to deliver our java applications to our windows users. However, our continuous integration build process occurs entirely on linux and automating the creation of installers is paramount. Does Advanced Installer support command line generation of MSI installers and can Advanced Installer be run from linux? Is it capable of being run under wine?
Please don't be confused. I am not asking if Advanced Installer can build a MSI that would install an application in linux. I am asking if Advanced Installer itself can be run under linux non-interactively.
Thank you.
Cosmin
Re: Support for generating MSI installers from linux
Advanced Installer does have a command line interface, but the application doesn't support Linux. Unfortunately Advanced Installer can run only on Windows.
Cosmin
LinuxDude
cosmin wrote:Thank you for your interest in Advanced Installer.
Is there any plan to fix that? A lot of us are developing under Linux and have Wine. It doesn't seem like it would be a big task to get AI working under Wine. After all, it runs everything from MS Office to IE to Google Earth.
Edit: I just tested out installing the Advanced Installer MSI file in Wine 1.01, and it did install and start up just fine. There were some minor visual glitches. I didn't try going further with it (using it to package something). But it seems like it's mostly there.
Cosmin
Advanced Installer can run on Wine, but we don't have full official support for it yet. However, other Linux platforms are not supported.
Cosmin
LinuxDude
cosmin wrote:Advanced Installer can run on Wine, but we don't have full official support for it yet. However, other Linux platforms are not supported.
It seems really close. I started creating a Java project for it, and I got to where I was adding files of the app, and that's where it hung.
It probably wouldn't take much effort to fix those things.
jasons2645
I am also looking into this product for my company. Everything is perfect - except the lack of a Linux command line, which is critical since all of our build servers are Linux. Without a Linux command line, we have no way to automate building of the installers or to provide continuous integration for the process. I fully expect that there are many other potential customers out there that are in the exact same boat.
Are there any plans to support a Linux command line? As noted in a previous post, a full GUI is not necessary - just a command line.
Thanks!
Cosmin
Advanced Installer is designed to work only on Windows platforms, so Linux support will not be included soon (we would have to re-write the application for Linux). However you can try using Advanced Installer on Wine.
Cosmin
LinuxDude
cosmin wrote:Advanced Installer is designed to work only on Windows platforms, so Linux support will not be included soon (we would have to re-write the application for Linux). However you can try using Advanced Installer on Wine.
I'm certainly not asking you to re-write it for Linux. That's a major task. What I am asking is for you to test it under Wine and fix the minor problems it has with Wine. It's about 99% of the way there. It would probably only need some very minor fixes to make it work 100% under Wine. You wouldn't release two binaries. It's just one thing that can install under either Windows or Linux+Wine.
That's how Google Earth works on Linux, for example. It's one Windows binary. On Linux it runs under Wine and it works great, no different from a native Linux application.
Cosmin
This improvement is on our TODO list and it will be available in a future version.
Cosmin
LinuxDude
cosmin wrote:This improvement is on our TODO list and it will be available in a future version.
Cool, I'm glad to hear it.
jos
Just to mention that we in our company are looking for exactly the same and for exactly the same reason.
We have a software product which works on Windows, Linux and Mac. There is one buildscript which runs on linux, compiles to java jarfiles and should generate installers for all supported operating systems.
For Windows we bought Advanced Installer because internal evaluation showed it is the best product to embed a Java runtime environment. But it we would be great to avoid the two-step and two-machine build process we currently have.
If AdvancedInstaller commandline works in wine, we can again have a build system on linux which builds everything, fully automated, on-the-fly for every code commit.
The error we have is this
wine ../Program\ Files/Caphyon/Advanced\ Installer\ 7.1.3/AdvancedInstaller.com /build ourproduct.aip
[ DefaultBuild ]
Exception - Error opening database file '�
There seems to be some corruption in the database filename ?
troc
Has there been any movement on this ?
jos
We eventually decided to use cygwin + virtualbox to scp from the buildscript to the virtualbox, execute advanced installer commandline, scp it back
it's a huge inefficiency but the best we found.
I hope linux will be a supported build platform sooon.
Cosmin
Unfortunately our developers were busy with other major features. However, this improvement is still on our TODO list and hopefully it will be available soon.
Cosmin
wybrand
Hello.
Is the 'advanced-installer-runs-under-wine' improvement yet been realized? I saw the last reaction from Cosmin was of late 2009 and its now 2011.
It would be a great thing if Adv. inst. could be run under wine since we do all our development under linux.
Greetings,
Wybrand.
Return to “Feature Requests”
