Heike
on OS Windows Server 2008 installation doesn't work
Hallo!
Installing my MSI (32-Bit Package) on Windows Server 2008 SP2 doesn't work.
It says that the OS hasn't got the right version and installation is stopped.
I've selected as Supported Operating System "Windows NT from" "Windows Vista Service Pack 1".
On Windows Vista the MSI works perfect.
There are the complete OS infos in the attachment.
Thank a lot for help in advance!
Heike
Heike
Re: on OS Windows Server 2008 installation doesn't work
Sorry!!! Wrong section of forum. But I hope I will get an answer. Thanks a lot!!
Cosmin
This behavior is caused by a bug in the launch condition. A bugfix will be included in a future version. Thank you for bringing this to our attention. Until then, you can try this:
- open the .AIP file with a text editor
- find the "caphyon.advinst.msicomp.MsiLaunchConditionsComponent" component
- set the "Condition" attribute to:
Version9X OR VersionNT64 OR ((VersionNT > 600) OR ((VersionNT = 600) AND (WindowsBuild = 6001) AND (ServicePackLevel >= 1)) OR ((VersionNT = 600) AND (WindowsBuild = 6001) AND (MsiNTProductType = 3)))
- save and close the file
- rebuild the project
This way Windows Server 2008 should be recognized correctly.
Cosmin
Heike
Hi Cosmin,
fine! Thanks a lot for that fast answer!!
Regards
Heike
Heike
For others having perhaps the same problem, this condition works (see WindowsBuild numbers):
Version9X OR VersionNT64 OR ((VersionNT > 600) OR ((VersionNT = 600) AND (WindowsBuild = 6001) AND (ServicePackLevel >= 1)) OR ((VersionNT = 600) AND (WindowsBuild =6002) AND (MsiNTProductType = 3)))
Regards
Heike
steveb
Has this issue been fixed?
I am having the same/similar problem with a launch condition. When I run my installer on 32bit 2008 server it prompts saying that it can't be installed on an OS earlier than windows vista 64bit. This prereq is for 64bit only and not 32bit.
Sj
Cosmin
For the condition mentioned in the above posts you can using:
(MsiNTProductType > 1)
This way domain controller machines will be supported (MsiNTProductType can have the values 2 and 3). With the current condition only server machines are supported. An improvement for this will be included in a future version of Advanced Installer.
If this doesn't help, can you please send us the .AIP (project) file you are using to support at advancedinstaller dot com so we can investigate it?
Cosmin
Return to “Feature Requests”
