I would like a way to clean out the download folder so that previous install files don't pile up. I noticed during my testing of auto update that over time there can be many installation files downloaded. if they are large then there is a lot of disk space wasted.
I tried giving the install files the same name from version to version but the auto updater would not download a new installer if it sees an installer with the same name already in the download folder. Perhaps another solution would be to have AI check the version or size of the install file to be downloaded and overwrite the file in the download folder if necesssary.
