I have an aip file, using the simple UI. After some recent changes (adding some more binaries, and a file removal), the simple UI has started prompting the user to close applications prior to running the install.
I can't see what changes would have triggered this. Can you tell me what makes the UI ask the user to close applications prior to continuing? Is there any way to prevent this behaviour - i.e. force the install to proceed without asking the user to close running apps?
Thanks in advance,
David.
