Trax
Could not access network location
During our install we have a few files that need to be copied from a shared path to out folders. I created a search path that is based off of a registry value that points to that shared path. I then added a Propertybased folder to "Files and Folders" based off that search. I then added File Operations to copy the files using the PropertyBased folder as its Source Folder. The problem we are having now is that our Shared Folder has changed and when we try to install a new MSI using the new Shared Folder Path or just try to uninstall the current MSI we get an error saying "Could not access network location..."
Any Ideas or help about this issue? Also did I go about setting this up the right way?
Thanks in advance.
Cosmin
Re: Could not access network location
This is the normal Windows Installer behavior. If the path of the shared folder may change after the install and before the uninstall, it is not recommended to use it for a folder in the package. To remove or fix the broken installer you can try one of the approaches explained here.
Instead of using a file operation you can try using a custom action. Perhaps this thread will help you:
http://www.advancedinstaller.com/forums ... 65&p=17734
You can also find some sample VBScript code here.
Cosmin
Trax
Thanks for the help. The Windows Installer Cleanup Utility worked for us
murali
Hi Frendz,
Am using java application through winndows installer tool...appliction build succesfully but once am running my applicationsome problem is coming
The problem is : could not access network location your value JavaProductDemo(this is my main application name)
please give me anybody the good answer as soon as possible earlier am waiting your's response
This may happen if one of your installation folders is resolved to an invalid path during "CostFinalize" standard action. In order to achieve this behavior you should make sure that the related installation folder is resolved to a valid path before "CostFinalize" standard action. Please take a look on our "Installer error when default location is not reachable" thread which debates a similar issue.
Also, you can take a look on our "Install files in a custom folder" article which could be useful for you.
If this doesn't help you, then please send us the .AIP (project file) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them.
