brahn
auto-updater: links, other HTML on "updates found" screen
I'd love to have more control over what appears in the message section of the auto-updater's "updates found" screen, i.e. the lower section of
http://www.advancedinstaller.com/album/ ... n-shot.png
For example, I'd like to include links, other basic formatting, or (even better) general HTML.
This would be particularly handy for those who store release notes elsewhere (e.g. online) and just want those same release notes to appear in this screen.
I don't suppose there's any way to do this now...?
Thanks!
brahn
Re: auto-updater: links, other HTML on "updates found" screen
As a follow-up -- it looks like I can use some basic RTF syntax, e.g.
\b make this text bold\b0
but not hyperlinks:
{\field{\*\fldinst{HYPERLINK "http://google.com"}}{\fldrslt this is the linked text}}
doesn't seem to work (it produces plain text that looks like
This is the linked text <http://google.com>
Cosmin
Currently the updates description supports only RTF format. However, HTML support is on our TODO list and it will be available in a future version.
Cosmin
brahn
cosmin wrote:Currently the updates description supports only RTF format.
Is the RTF support supposed to be complete, or limited?
As mentioned above, I couldn't get links working. If there's some other syntax I should be using, please let me know.
cosmin wrote:HTML support is on our TODO list and it will be available in a future version.
Very glad to hear it. Thanks!
Cosmin
Is the RTF support supposed to be complete, or limited? As mentioned above, I couldn't get links working.
Currently links are not supported. However, this improvement is on our TODO list and it will be available in a future version.
Cosmin
brahn
OK, thanks for the clarification!
Return to “Feature Requests”
