Bernd
Rename Updater (EXE) after download
this might be possible but I cannot find it in the documentation:
I have a problem using auto update because my web hoster seems to put some restrictions on EXE files.
The problem manifests in that when I enter the (correct) update URL (e. g. http://.....//myupdate.exe) into the browser I get "FILE NOT FOUND".
Doing the same with a text file works.
When running the AI Updater this results in a "wrong file size" error.
One solution would be (if this cannot be "fixed" by our web hoster) to name the file on the server as "myupdater.xxx" and renaming it during/after download using a special entry in the configuration file.
Is this possible?
/BB
Sorry, but I found out how to do it!
I simply named the URL .... myupdate.exe.txt. AI puts the "right" name in the ServerFile entry and it works w/o problems. Thanks for this great product!
/BB
