Error 2893 - Long Directory Path
Having trouble running Advanced Installer? Got a bug to report? Post it all here.
hmxchooch
Postby hmxchooch » Mon Jul 13, 2009 6:50 pm
Our QA encountered this error with v7.0.1 of Advanced Installer. I am wondering if there is a way to get a better error string.
Bug Report:
Confusing error message when exceding the install path character limit. The current error message reads as though there is an issue with the installer, when the real problem is that the selected path exceeds the character limits.
To reproduce:
1. Run setup.exe
2. Progress through to the Custom Installer screen
3. Set the install path to a series of folders that exceeds 260 characters (ie: C:\asdasfasasfasfasasfasfa<...> for 260 characters)
4. Attempt to install into that path.
Results: The following error message is generated:
'The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2893.'
Expected: Error details that the selected directory path exceeds the character limit.
If I enter another error string into ui_en.ai, can we give this error a custom response? Does this error code appear in any other circumstances?
Thanks for your help!
- Chris
Contact:
Re: Error 2893 - Long Directory Path
Postby Bogdan » Tue Jul 14, 2009 11:19 am
For a custom message to appear you must do the following modifications:
- go to ui_en.ail file, from the install path of Advanced Installer, and add the following line:
   <STRING id="Error.2893" value="Here is the error message that will be displayed."/>
- this is the line that will contain the error message
- after that go to “fragments” folder from the install path of Advanced Installer
- open StaticUIStrings.aip file with a text editor and add the following line next to the other errors references from the file:
<ROW Error="2893" MessageLocId="Error.2893"/>
- save both edited files
- close your .aip project, if opened.
- open the project, build and run
From now on this error should appear with the message you enter.
Who is online
Users browsing this forum: No registered users and 1 guest
