jesusilvester
Prerequisites are not running with msi
hi ,
The prerequisites screen is coming only with the EXE version and not msi version.
We need the ouput in Msi since we will be using the package as chained packages.
Need your help in this
Jesukaran John Silvester
Re: Prerequisites are not running with msi
Only MSI files can be added as chained packages.
However, you can add the prerequisites that you need for a certain MSI this way:
- create the MSI file without including in it the software prerequisites
- add the MSI file to the main installer, along the other MSI files
- in the main installer, go to Prerequisites page and add here the prerequisites required for the MSI file that you've created earlier(but not included the prerequisites for it)
This way you will create a chained package with all the necessary MSI files and the prerequisites required for each of them.
