SillyPutty1000
Clean up of unused Components
How do I clean up of unused Features And Components?
Over a period of testing thousands of files....I have added and deleted many files and I have lots of duplicated entries in the Features And Components Panel. How do I perform a clean up of unused Features And Components?
Is this possible?
thanks
Cosmin
Re: Clean up of unused Components
Please note that each component is associated with at least one resource from the project. Therefore, the components can be removed only by removing the actual resource (file, registry entry etc.) from the project. To remove a feature you can remove it's components or move them to another feature.
Cosmin
Return to “Feature Requests”
