Yes you can translate it. Here is what you have to do:
- go to Install Parameters page and create a new property in the Properties group called for example MY_PROPERTY.
- after creating the property → right click on it → Edit
- in the Value field → right click → Localization
- in the Localization dialog that will appear make this settings:
–- “Always translate this string”
–- “Using specified localization identifier” and fill in the edit box with ,for example :
- in your custom action use the name of your property like this :
- in the Translations page ,after you've selected the languages you desire, create a new dictionary using the “Create” button and following the wizard.
- open the dictionary file you've created with a text editor and find the component IDENTIFIER defined by you.
- edit the lines that look like this :
<STRING lang="en" value="error message in english"/>
<STRING lang="fr" value="error message in french"/>
etc...
- go to Dictionaries tab and add the dictionary you've edited
- save your project, close AI and reopen it to be able to see the new dictionary
This should allow you to display the error messages localized.
