RandomName
Please select a registry value containing a string!
I'm trying to check for the existence of a registry value for a prerequisite, unfortunately Advanced Installer will not allow this.
I'm not sure why it would matter what kind of registry value it is if I'm only checking for its existence.
MindTooth
Re: Please select a registry value containing a string!
What criteria are you using?`
Birger :)
RandomName
I'm checking for the Flash ActiveX plugin:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Active Setup\Installed Components\{D27CDB6E-AE6D-11cf-96B8-444553540000}\IsInstalled
It seems odd that Advanced Installer cannot read binary values for validation, but it's gotta be a bug that it can't even check for the existence of that value.
GabrielBarbu
There appears to be a bug in the search for whether a registry value exists. We have added this issue on our TODO list and a bug fix will be included in the next release of Advanced Installer. Thank you for bringing this to our attention.
Gabriel
Gabriel Barbu
Advanced Installer Team
