Hi all, I'm a freshman in setup development and hope you could help me.
We developed a tool to manage the licensing processes while the setup is running. The EXE ist build in Microsoft VS2008 (NET). Cause of that the EXE will need some Resource Files run correctly and to display some informations. The resource files are placed in few subdirectories. Moreover the managing tool need some parameters on startup.
Thereby I added a Custom Action to our setup project ("Launch File or Open URL") to run the EXE and transfer the parameter by the command line. But it does't work. It can't find the resource files.
Hereafter I find the Custom Action "EXE with working Dir". But there is no "Command Line" option like in "Launch File or Open URL". Is these the right type of custom action to solve the problem? How I can transfer the parameters? We have to place the tool in the msi package (the tool may not be placed on cd oneselfe), but we don't want to install the tool on a local machine. How/Where I have to place the directories and files of the managing tool?
If there is no way to solve the problem under these handicaps, how it will work?
Due to the VS2008 the .NET Framework is needed while installation. It is possible to add loaunch condition at the prerequisites. So that the setup will only run if the .NET Framework is installed. But we want to deliver the Framework within the setup package. Is it possible to install the Framework directly at the start? How I have to check whether the framework is already installed? How I have to check the framework version?
