srini
Changing label text from VBScript
I am trying to change the text of a label from the VBScript using the Session.Property method. But this does not seem to be working. I have associated the label to a property. Is there anything special should I do to change the label text?
GabrielBarbu
Re: Changing label text from VBScript
You may want to update your label text either with or without Enhanced UI.
With Enhanced UI
In order to initiate a refresh on an Enhanced UI Dialog, you only need to set the AiRefreshDlg property. Each time AiRefreshDlg is being set, the user interface refreshes.
Below is a sample script that increments a property, then refreshes the dialog to display the updated property
Dim x
x = Session.Property("MYPROP")
x = x+1
Session.Property("MYPROP") = cstr(x)
'setting AiRefreshDlg refreshes the controls on a dialog when Enhanced UI is enabled.
Session.Property("AiRefreshDlg") = cstr(1)
Without Enhanced UI
The UpdateMsiEditControls Custom Action is responsible for refreshing an MSI dialog. Described below is the proper usage of this custom action.
- on the Custom Actions page, right click "UI Custom Actions" and select "Add Predefined UI Custom Action"->"Update MSI Edit Controls"
- this custom action needs to be called after the published event that changes the property, as seen in the screenshot below.
Also, below is a sample project that implements this for both cases.
Sample.zip
(3.35 KiB) Downloaded 443 times
Gabriel
Gabriel Barbu
Advanced Installer Team
srini
That is sorted. Thanks Gabriel.
